Sunbeam? Not sure. If you can find a datasheet on the Sunbeam I can help you figure it out. A standard Energizer will last about five hours. Assuming the Sunbeam has less capacity, I'd guess you'll get 3-4 hours out of it.Whew, okay, good. So how long would this battery last in it?
Can you explain how to switch the slider with the reed switch?
- Bend the metal bracket back so it is no longer pressing against the board OR desolder it - heat the base of the bracket with your iron until you see the solder around it liquify then pull it off.
- Remove the plastic slider.
- Solder a wire to the base of the metal bracket or, if you removed the bracket, solder the wire to the pad on the board where the metal bracket was.
- Solder the other end of this wire to the end of the reed switch with the single lead.
- Solder another wire to the pad on the board where the plastic slider was positioned.
- Solder the other end of this wire to the longer of the two leads on the reed switch.
