HI guys thanks for your insight and help if some one would be as kind to proof read my answers for my assigment would much be helpfull to me my first page is fill in the right terms or words.
red will be my answer and a couple i dont know i would be open to any help if use didnt mind.
A) A simple electrical circuit consists of conductors connecting the voltage source to the load.
B) A switch is always provided in a circuit to interrupt or isolate the current.
C) An "open circuit" means the ciruit is Broken
D) An "over load" in a circuit occurs when the current is excessive.
E) The name of the unit to measure resistance is the ohmmeter
F) When measuring current the multimeter is always connected in Series with the load.
G) In a simple parallel Circuit the Voltage is the same across all components.
H) Resistors connected in parallel have a total resistance value that is less than the smallest resistor value.
I) If 10 resistors, connected in parallel have a value of 5 are connected in series. The total circuit resistance will be ???
J) When measuring D.C currents and voltages the Function or setting of the meter must be considered.
K) A mulitmeter can be used to measure voltage,current,resistance
L) DC means the current in the circuit is flowing in only one direction
M) A capacitor allows electrical current to flow through it.
N) in a telecommunications network you will find various types of currents, these are both ?? and ??
O) An inductor will allow ac through
P) in a telephone circuit you will find a capacitor in the ?? circuit to stop the ?? current flowing in the circuit.
