An Electronic Welder Circuit Question
Discussion in 'General Electronics Chat' started by BlackMelon, Nov 30, 2015.
  1. BlackMelon
    Mar 19, 2015
    33
    I'm repairing a welder. Its schematic is in the pdf file. For my doubt, I want to know about a gate driver circuit in board C. What kind of driver is this?
    (The signal measured between Red(S)-C and White(S)-C is depicted in the image file. Its peak and crest are +21.4 and -21.4 consecutively)
    Thank you
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    I would call it it a steering diode array. The positive half cycle goes one way and the negative half cycle goes by a different path.
  3. BlackMelon
    Mar 19, 2015
    33
    Could you clarify more about its operation? In a certain mode, which switching devices are on and which are off?
  4. BlackMelon
    Mar 19, 2015
    33
    According to the schematic and running a test previous, the zeners D13 and D12 and capacitors C2 and C10 had been toasted, so they are desoldered out from the circuit.
    https://www.mediafire.com/?89nyx8uxs51i00w
    Here, I've got signals of Red2(S)-C and White2(S)-C with respect to a MOSFET's source (S). For a scope settings, I checked that my ground levels of both channels were set at Y=0 on displaying screen, and signals are measured in DC coupling mode. The signals swing below 0V.
    The yellow trace = Red wire
    The blue trace = White wire
    https://www.mediafire.com/?53vf2r75x15s9qc
    What's more, this is a video showing gg and a MOSFET's gate signals respected to a MOSFET's source (S).
    The yellow trace=gate
    The blue trace = gg
    Could you please analyze its operation?
    Thank you
