an electronic circuit detects open and short circuit
Discussion in 'The Projects Forum' started by mae2008, Feb 8, 2009.
  1. mae2008
    Dec 1, 2008
    Dear Friends
    I want to build a circuit that detect a short and open circuit between two wires. when the two wires are short, a led lights when open, led turn off.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. NavjeetSingh
    Feb 8, 2009
    9
    If I'm getting it right then you should be able to do it very easily.
    Just take a battery , connect it with a wire to LED . Put a switch and crocodile plugs in between and your circuit is ready.
    Method to Test: Put the crocodile pins on the terminals of the circuit or wire arrangement. IF the Led glows circuit is intact and if doesn't it's open.
    I hope it helped you.
  4. flat5
    Nov 13, 2008
    403
    17
    "Just take a battery , connect it with a wire to LED .
    Put a switch and crocodile plugs in between and your circuit is ready."
    Not quite. A current limiting resistor is needed to not burn out the LED.
  5. KMoffett
    Dec 19, 2007
    2,586
    234
    Are the wires attached to a device?...a circuit?...power?
    Ken
  6. Bernard
    Aug 7, 2008
    4,244
    423
    This is a little old but it worked circa 1955, cable 13 twisted pair ,1400 ft,long. Normal procedure for breaks was to flex cable and hope to get a hit; slow and unrelyable; I designed a cable fault panel which switch select faulted pair: 1 check capacity vs good pair, with bridge ckt.to determine approx. distance; inject a 4kHz signal and with hand held high gain amplifier & head phones quickley found exact point of break. Could also measure resistance compaded to good pair to find approx location of short. No LEDs back then.
