An Easter Conundrum
Discussion in 'Math' started by studiot, Apr 8, 2009.
  1. studiot
    Thread Starter AAC Fanatic!
    Nov 9, 2007
    5,005
    515
    Most folks have no trouble doing a 3-4-5 triangle, however there are other interesting ones some even without right angles.
    None of the sides in the obtuse triangle in the sketch are whole numbers, yet each forms a whole number when squared. So the squares on each side have whole number areas.
    What is the area of the triangle itself?
    Is it also a whole number?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    28 using Heron's formula.
    John
  3. jasperthecat
    Member
    Mar 26, 2009
    20
    From your diagram
    the lengths of the sides are Sqrt(41), Sqrt(97) and 14
    using
    area = sqrt(s*(s-a)*(s-b)*(s-c))
    where a,b,c are sides and s = semi perimeter
    I'd be surprised if the area is a whole number
  4. jasperthecat
    Member
    Mar 26, 2009
    20
    My surprise for the day
  5. Ratch
    Mar 20, 2007
    1,068
    To the Ineffable All,
    A simpler way is to drop a perpendicular line from the top vertice to the base. Then solving x^2+y^2 = 41, (14-x)^2+y^2 = 97 , where x is the distance from the left vertice to the perpendicular line and y is the altitude of the triangle. Solving, we easily get y=4 . So (1/2)*(14)*4 = 28
    Ratch
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    The answer I obtained was 28.
    hgmjr
  7. zgozvrm
    Member
    Oct 24, 2009
    115
    Whoops!
    If you meant for the sides of the triangle to NOT be whole numbers in order to make the problem more difficult, you failed ... you have the square on the bottom of the triangle as having an area of 196 sq. m. The square root of 196 is 14 which IS a whole number!
