An array name as a constant pointer to the first element of the array Please explain
Discussion in 'Programmer's Corner' started by integral, Jun 27, 2011.
  1. integral
    Aug 19, 2010
    22
    The book I am studying from makes the following two statements:
    1. The array name (without a subscript) is a (constant) pointer to the first element of the array.
    2. The name of an array is actually the address in memory of the first element of the array.
    When I run the following program:
    Code ( (Unknown Language)):
    1. #include <iostream>
    2. using namespace std;
    3.
    4. int main()
    5. {
    6.     int b[5] = {11, 22, 33, 44, 55};
    7.     const int *bPtr =  b;
    8.
    9.     //Part 1
    10.     cout << "Part 1" << endl;
    11. [COLOR=Red]    cout << "b  = " << b << endl;
    12.     cout << "&b = " << &b << endl;[/COLOR]
    13.     cout << "*b = " << *b << endl;
    14.
    15.     cout << endl;
    16.
    17.
    18.     //Part 2
    19.     cout << "Part 2" << endl;
    20.     cout << "bPtr  = " << bPtr << endl;
    21.     cout << "&bPtr = " << &bPtr << endl;
    22.     cout << "*bPtr = " << *bPtr << endl;
    23.
    24.     return 0;
    25. }
    I get the following result:
    1. Part 1
    2. [COLOR=Red]b  = 0023FEAC
    3. &b = 0023FEAC[/COLOR]
    4. *b = 11
    5.
    6. Part 2
    7. bPtr  = 0023FEAC
    8. &bPtr = 0023FEA8
    9. *bPtr = 11
    10. Press any key to continue . . .
    11.
    I don't understand why the lines in red above produce the same output. I understand why b = 0023FEAC but why does &b = 0023FEAC ? If my understanding of pointers is correct, it seems like it is a pointer pointing to itself.
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    First of all, integral, this is an excellent post -- I wish all the people who had questions gave code properly indented like you did, added the highlighting, and showed the output. It's quite refreshing from the manifold poorly-phrased and poorly-presented questions one often sees here. Many posters aren't smart enough to realize they're asking for a favor, so they should minimize the amount of work the reader has to do.
    I recommend you use Stroustrup's C++ book for such questions (rather than e.g. K&R); I'm using 3rd ed. On page 91 is the statement "The name of an array can be used as a pointer to its initial element". Then the example following shows that, semantically, the array's name can be used as a pointer and Stroustrup mentions an implicit conversion. This is a subtle point. Note the statement is that the array's name can be used as a pointer -- that does not mean it is a pointer.
    Thus, your line "cout << b" does an implicit conversion to a pointer, which then prints as the usual hex value. Here's some code:
    int a[3] = {0, 1, 2};
    int *p = a; // Implicit conversion to pointer
    The following three lines are semantically equivalent:
    int *p = a;
    int *p = &a;
    int *p = &a[0];
    However, I believe no implicit conversion would need to be generated for the last two lines (look at the assembly to be sure).
    Thus, semantically, a, &a, and &a[0] behave the same way. That's why you get the same address in the printouts. a is an array, but &a and &a[0] are addresses -- two entirely different things.
