Ampule Spinner
SgtWookie
Joined Jul 17, 2007
22,230
Here's another idea for a motor:
http://www.mpja.com/191VDC-82-RPM-Gearhead-Motor-Used/productinfo/18609 MD/
And a suitable power supply:
http://www.mpja.com/12-Volt-Plug-In-Power-Supply-1A-Hon-Kwang/productinfo/19466 PS/
The motor has a 30-tooth steel gear on the shaft. What I'd do is take a short chunk of 3/4" I.D. heater hose, and make 3 or 4 slits down the sides, so that one end can spring open to accept an ampule. The other end gets secured to the gear using a worm-screw type clamp. You may need to cut a couple of slits in the gear end of the hose, too - so that it can slip over the gear. You could use some rubber bands to increase the holding tension on the top end if required. Build a small stand for the motor out of some wood scraps.
Bernard
Joined Aug 7, 2008
5,784
Swing-out Ampule Spinner illustration. B- weighted base, 6" dia 3/16 steel; M- approx. 60 RPM gear motor; H- holder, tubing per The Sgt, or plastic tube lined with glass cloth; S- support, 1/4 " X 10" steel or Al rod; J -height adjusting collar.Ampule Sealer 00000.jpg
Might add swing out stop & or foot switch motor control.
Iron Monkey
Joined Nov 6, 2014
9
Iron Monkey
Joined Nov 6, 2014
9
Great links and great Idea too. This sounds like it would be just like the one in the video or very similar. But really I don't even know how to connect the motor to the power supply.
If i didn't find this forum i wouldn't even know where to start as I really have little knowledge about these things. Thanks or all the help and ideas you guys are giving me.
I've done a lot of ampule sealing long ago and of the same general size.
To make life really easier on yourself when you have (or do you) seal it in a vacuum, neck a smaller tube to the larger tube. e.g. 1 cm attached to your 32 cm diameter tube.
Necking one side down isn't that hard. I used quartz with a hydrogen/oxygen flame (purity reasons). At one point, we sealed stuff in square cross-section tubes.
The compound synthesis was done using the large tubes. Later, I did crystal growth.
Two torches, basically. One was bench mounted and had both a wide an narrow flame. The other was hand held. The vacuum system was roughing + a diffusion pump and Perani and thermocouple vacuum gauges.
The final seal was done with the samples at basically eye level. The system was basically made of glass and 4 samples could be pumped at a time.
For a turntable, you could use an AC synchronous motor at about the speed you need and vary it with a simply made variable speed drive. I designed one for a co-worker's telescope once. Frequency determines the speed. So, we used a 120 V synchronous motor and I used a transformer to change a +12 V to 120 V variable frequency.
djsfantasi
Joined Apr 11, 2010
9,163
I used a motor with a worm gear driving a gear connected to the bottom of the ampule holder. The holder is a tube, lined with foam to hold the ampule. The bottom of the tube, has an axle which is supported below.
The wiring is very simple.
