Amps
New123
Joined Jan 3, 2013
13
How does a portable jump starter produce up to 1000amps from a 12v battery. Also what type of batter is it
strantor
Joined Oct 3, 2010
6,798
1000 amps could be produced from even a 1V battery. Likewise a 1000V battery may not even be able to produce 1A. it depends on the internal resistance of the battery in question. Very low internal resistance = very high amp output, and vise versa. Google ohm's law.
I don't know what type of battery is common in a car jump starter, but I suspect it's some variant of the lead acid battery like the one that is already in your car. The lead acid battery in your car is also likely able to produce 1000A, as it is a low resistance battery.
GopherT
Joined Nov 23, 2012
8,009
Lithium polymer battery is small and very low internal resistance.
Remember, a real battery is the same as an "ideal battery" plus a resister in series with the battery.
New123
Joined Jan 3, 2013
13
Ok. So if I were to remove all resistance from a lithium ion battery ( ex. Laptop battery 11.1v) could I produce similar amperage
JMac3108
Joined Aug 16, 2010
348
Most I've seen use a 19ah sealed lead acid battery.
19Ah is the battery capacity in amp x hours. This is unrelated to the amount of current the battery can source. As others have said, this is only limited by the internal resistance of the battery. I once designed a UPS battery pack with individual sealed-lead-acid cells and they actually specified a "short-term short-circuit current" in the datasheet. I remember it being about 400A.
JMac3108
Joined Aug 16, 2010
348
I don't know. I'm just wondering if its possible to produce 200amps from a 12v lithium ion battery.
Nope. Regardless of internal resistance, the internal safety circuit in a LiIon battery will disconnect the battery before allowing an excessive current.
And if you tried to use raw LiIon cells and draw a very high current from them you would heat them up and find out why we always use a safety circuit!!!
vrainom
Joined Sep 8, 2011
126
I was answering op's question "what kind of battery is it". And most jump starters I've seen use that particular battery capacity. Sure, they can give an instantaneous huge amount of current.
thatoneguy
Joined Feb 19, 2009
6,359
This URL is about Energizer AA battery Internal Resistance but it gives you an idea of the deciding factor for what a battery can deliver.
For example, a CR2032 Lithium coin battery and a CR123 Lithium Cell (half length AA battery and a bit fatter) both have about 3 Volts at the terminal.
The Coin Cell, due to construction and physical size, can only output about 20mA when terminals are shorted.
A CR123 Cell can provide >10 Amps when the terminals are shorted.
The downside of Lithium Cells, especially rechargeable Li-ion, is during heavy current flow, they heat up and tend to catch fire or explode. This can happen either in discharging (both types), and especially in Li-Ion Rechargeable (Flaming notebooks).
Lead Acid is the best chemistry for very low internal resistance for short bursts of very high current. When a battery goes "bad", it is due to the internal resistance climbing, for one reason or another.
