Meaning the tip will be thinner?Yes, the tip has a step and is thinner. The video shows an ineffective tip that does not have the step, so all the tips I will be making this week have the step.
Yes, it will be thinner.Meaning the tip will be thinner?
Good. That means it will have a higher resistance than the rest of the cylinder because it has a smaller cross section. That will concentrate the heat in the tip.Yes, it will be thinner.
I've been doing some research on different types of transformers to see if there's a design that may help with my application (rather than just a standard laminated transformer). I have come across a few that sound like they may help, but I really am not sure.You could probably rewind a MOT (microwave oven transformer) with 1 or 2 turns of wire for your transformer. Or try the Weller soldering gun.
Either way is okay. Torroids are usually a little more expensive, but smaller. They do however: suffer from high inrush currents.I've been doing some research on different types of transformers to see if there's a design that may help with my application (rather than just a standard laminated transformer). I have come across a few that sound like they may help, but I really am not sure.
Out of all the transformer variants, are there any that may help with my application? I was thinking about a high impedance transformer to reduce the inrush, and I'm also wondering how a toroidal transformer may impact the heating (the engineer working on the project before me tried to use toroidal transformers, but I'm not sure why he picked that style).
Another question, is there a way to vary the output voltage on the transformer other than having multiple taps on the primary? I'd like to vary the output voltage from 1.5V to 3.0V.
