amplifying square wave
Discussion in 'Homework Help' started by neiji, Mar 11, 2008.
  1. neiji
    Jul 25, 2007
    19
    suppose there is 0.5V peak to peak square wave, how is it possible to make it become a 3V pk to pk square wave?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. scubasteve_911
    Dec 27, 2007
    1,202
    Yes, as beenthere said, you can use a non-inverting opamp circuit to do this. The non-inverting configuration will not load your input signal, even if it is really high impedance.
    The only real considerations you need to ensure are: make sure your opamp's output can swing to +/-3V (Should be okay with +-5V supply rails), make sure your slew-rate of your opamp is adequate (impossible to get a true square wave), and ensure that your opamp can handle the load you are driving.
    Steve
  4. Distort10n
    Dec 25, 2006
    429
    Don't forget that your op-amp has to have enough bandwidth. Do not expect a 100kHz square wave to be reproduced with a gain bandwidth product of 200 kHz.
