Hello guys,
I need to amplify a micro/nano Amp current signal. Then I need to convert this amplified signal to a voltage so a 10 bit analogue to digital converter can read it. I assume I would use some sort of current amplifier followed by measuring the output voltage across a resistor. Is there anything I am missing that the experienced/clever heads in this forum can point out! Thanks in advance,
Ping.
p.s if anyone knows of any good current amplifiers please suggest, thanks.
Ping.
