amplifying LED signal
Discussion in 'The Projects Forum' started by davivid, Aug 24, 2011.
  1. davivid
    Aug 24, 2011
    I need to amplify the output channels of a TLC5940 to drive more LEDs.
    I have been recommended a TIP107 to do this, how do I wire it up?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    LEDs, 555s, Flashers, and Light Chasers
    Chapter 10
    What you are wanting is more current drive, each extra LED requires a little more. Putting them in series will help, instead of wasting current as heat in the current limiting resistor you are using it in the LED.
    You will need to provide more information, such as power supply, color of the LEDs, quantity of the LEDs.
