Hello, I am trying to make a variable resistor based on a changing load impedance on output of an amplifier. I am a novice to electronics so I cannot do this alone unfortunately.
I have come to the conclusion that measuring the RMS of the AC signal on the output is probably the best way to determine a changing impedance.
This is what I made so far using an LTC1966
The difference between a 300 ohm impedance and a 500 ohm impedance is about 2mv on the IC. So I want to use a Jfet to act as a resistor that will allow an adjustable voltage between 75-78ish volts depending on the output of the IC.
I'm totally out of my league on this so help would be appreciated.
