It was a j/k. Seems that MUSES01 is the Bose of op-amps.
It probably isn't even close to being like a human ear, which can adjust down to 0 db I think. But does this practice of paralleling mics work in theory and practice?I custom built a stereo microphone from arrays of 5 mic capsules in parallel at each channel. Such an array assembly helps to dramatically raise the S/N ratio: the audio signals from the capsules add up because of their synchronicity while the noise from the individual capsules (which is stochastic) tends to cancel out. The mics I used had a sensitivity of -58dB (IIRC), the best I could get at this size and at a reasonable cost at that time. I estimated that the sensitivity of the whole assembly (microphone array and dish) is comparable to that of a human ear. Not bad!
by Jake Hertz
by Duane Benson
by Jake Hertz
