I'm trying to amplify a 25mvp, 40Khz sin wave to 0-3.3v in order to feed it to an ADC.
I've aimed for 2 cascaded inverting op-amps with 11 and 6 gain, respectively, with a dc bias given by the v+ on the first stage.
Although I'm getting a weird answer from the second stage.
On the leftmost osciloscope you can see the input signal , on the rightmost one you can see the first stage opamp output after the buffer and the second stage output below.
LM6134 are rail to rail single supply able, 5v common voltage range opamps.
Can you please help me solving this problem?
Thank you.
Thank you.
