I need to boost automotive voltage(12-14 volts) to 16 volts at 5 amps. Can someone point me to a good device to use for this? I've found a LM324 op-amp but I'm not sure if this is the right way to go.
I kinda get what you're saying but I'm a analog circuit newbie andA wild thought: an alternator supplying two different battery banks via a diode OR gate adds another diode drop from rectifier to regulator so armature current is increased so output V is increased to compisate for OR diode drop; add a few diodes between your alternator and regulator to force output to 16 V ?? Diodes need to be about 5 A. Have not tried it myself
The alternator does not have an internal regulator, itThe alternator will have an internal electronic module to regulate
the voltage.
by Duane Benson
by Don Wilcher
