amplifiers
Discussion in 'The Projects Forum' started by gani775, Jan 24, 2012.
  1. gani775
    Jan 19, 2012
    15
    From an F-V converter i have got voltage values..
    i.e for
    f(hz)-v(v)
    65hz - 5v
    100hz-9.85v.
    my next stage is feeding these output from f-v converter to an device (opamp\comparater) so tat i get an constant output 0f 5v for frequencies above 65hz, and for frequencies from 0-64hz it should provide 0v.
    so please suggest me ideas about tis.
  2. praondevou
    Jul 9, 2011
    2,936
    489
    A simple comparator circuit with an LM339 should do the job.
  3. gani775
    Jan 19, 2012
    15
    let the refrence voltage be 6v. then when input voltage crosses 6v it should provide 5v as output and if input is less than 6v vref,output should be 0v...
    so please suggest the circuit for this
