amplifiers
Discussion in 'General Electronics Chat' started by ronn, Dec 10, 2009.
  1. ronn
    Nov 1, 2007
    16
    What is the difference between an ac amplifier and a dc amplifier?
    thanks,
    Ron
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In general, an AC amplifier will have capacitors between one or more stages to eliminate DC offfset. A DC amp will amplify down to DC.
  3. studiot
    Nov 9, 2007
    5,005
    515
    You need to distinguish between
    An AC coupled amp v a DC coupled amp
    and
    an amp for amplifying AC v an amp for amplifying DC.
    Been There was talking about the first situation. In general a DC coupled amp presents no capacitors in the signal path and is therfore capable of amplifying DC. It is also capable of amplifying AC - up to its frequency limit. This does not mean there are no capacitors in the amp - there may be bypass and feedback caps.
    The second situation is more complicated as certain types of amps exist which amplify DC by converting it to AC - they are called chopper amps.
