Amplifiers
Discussion in 'General Electronics Chat' started by Skeebopstop, Feb 8, 2009.
  1. Skeebopstop
    Thread Starter Active Member
    Jan 9, 2009
    358
    I am so used to using op-amps to do all my amplification, when would it be appropriate to actually do BJT etc.. transistor amplifiers?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You might find such an animal useful when driving speakers and not earbuds. Op amps have a hard time handling +/- 75 VDC @ 12 amps.
  3. mik3
    Feb 4, 2008
    4,846
    63
    Op amps are more linear devices than BJTs and you can design easier. However, if you require high power outputs then you have to use transistors.
    What is the application?
  4. Skeebopstop
    Jan 9, 2009
    358
    Just inquiring for future design knowledge.
    So why not just op-amp into a buffer stage? i.e. emitter follower buffer etc..? Or a power push/pull?
    The component footprint of an op-amp amplifier seems like it would almost always be less, so easier to stick with op-amp and just buffer output.
  5. mik3
    Feb 4, 2008
    4,846
    63
    Yes, it would be better to amplify voltage using an op amp (if the voltage level permits) and then use a push-pull pair as buffer (amplify the current).
  6. Ron H
    Apr 14, 2005
    7,050
    657
    If possible, you should put the buffer inside the feedback loop. You will get better linearity (less distortion).
  7. Skeebopstop
    Jan 9, 2009
    358
    Aye, drives you through the cut-off regions. That is Class-AB yeah?
  8. Ron H
    Apr 14, 2005
    7,050
    657
    That seems to be the most popular choice.
  9. lespaul
    Jan 30, 2008
    49
    Most common high power amplifiers these days use an op-amp or BJT preamp section and a Mosfet output stage. I am currently touring with amplifiers that will drive 2500 watts into 4 ohms. The mosfet power stage is easy to bias and drives massive current with minimal distortion.
