Amplifiers Calculations
Discussion in 'Homework Help' started by Kayne, Oct 21, 2010.
  1. Kayne
    Thread Starter Active Member
    Mar 19, 2009
    105
    HI,
    I have come to the problem attached and have been given the answer from the text book but not sure how to calculate hie.
    The question asked for a value of input resistance of the circuit.
    The formula I am using is
     Rie= R1//R2//(hie+hfeRe)
    where
    hie =\frac{0.026}{Ibq}
    So
     = 18k//180k//(hie+(560\times200)
    Now Ibq is the bais current which I need but an unsure which numbers to use in the figure.
    Do I have to find out the current between the 180k and 18k resistors?
    Thanks for your time
    • Q1.doc
      File size:
      51.5 KB
      12
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    You forgot to attach the image.
    Be sure to hit the "upload" button on the Attachment Manager screen.
  3. Kayne
    Mar 19, 2009
    105
    Not sure what happened then on my screen the attachment was there. I have done it again.
    • Q1.doc
      File size:
      51.5 KB
      15
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Your formulas are correct, they have only a mild level of estimation (they assume \alpha \approx 1 which is ok).
    In order to find the bias collector current, as you correctly pointed, you need to do a DC analysis of the layout. Open circuit all the capacitors, and by doing this, isolate the circuit from the AC signal. We wanto to work only with DC quantities for now.
    See the section "Emmiter Bias" on this page: http://www.allaboutcircuits.com/vol_3/chpt_4/10.html
    You need to convert the voltage divider to its Thevenin analog to apply the above, so look at the next section, "Voltage Divider Bias", too.
  5. Kayne
    Mar 19, 2009
    105
    Looking though that link the formula I need to use is below
    IE= \frac{VBB-VBE}{\frac{RB}{Hfe}}
    So if I subsistute in my values I get
     IE= \frac{12-0.7}{\frac{(\frac{180k\times18k}{180k+18k})}{200}}=138mA
    I think that I am still doing something incorrect as I work further into the poblem the value for hie is incorrect compared to the answer.
  6. The Electrician
    Oct 9, 2007
    2,300
    335
    Let me describe a rough, first-cut, procedure that can also serve as a sanity check.
    You want the collector voltage, Vc, to be about half the supply voltage, Vcc.
    Calculate the current in the collector resistor, the 6.8k, which will drop about half the supply voltage: Ic = 6 volts/6800 ohms = .88 mA. This ignores the drop across the emitter resistor, but since the emitter resistor is less than 1/10 the collector resistor, it's ok for a start.
    If Ie is .88 mA, then re = .026/.00088 = 29.5 Ω, and hie = (β+1)*29.5 = 5929.5 Ω.
    If Ie is .88 mA, then Ib = Ie/(β+1) = 4.37 μA.
    Calculate the current in the bias divider: Id = 12/(18k + 180k) = 60.6 μA.
    This is more than 10 times the base current, so for a first approximation (and sanity check) we can ignore the effect of the base current on the bias divider output voltage.
    So, we can see that your value of 138 mA for the emitter current is probably wrong!
    There have been several long threads on this topic:
    http://forum.allaboutcircuits.com/showthread.php?t=27774
    http://forum.allaboutcircuits.com/showthread.php?t=25657
    Have a look in the vicinity of post #42 of the second thread.
