[Amplifiers] Calculating source-to-load voltage gain
Discussion in 'Homework Help' started by nDever, Feb 26, 2015.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hi guys,
    I'm doing some elementary amplifier exercises, and decided to do this one.
    An amplifier has a specified voltage gain of 100, input resistance 100k\Omega, and output resistance 10\Omega. Calculate the source-to-load voltage gain for a source resistance of 10k\Omega and a load resistance 100\Omega.
    Correct answer: 82.6
    My answer comes out to be the reciprocal of the correct answer; clearly, I'm going wrong somewhere.
    ____________________________________________
    Work:
    A_v=100
    R_{in}=100k\Omega
    R_{out}=10\Omega
    R_{s}=10k\Omega
    R_{L}=100\Omega
    v_{in}=\frac{R_{in}v_{s}}{R_{in}+R_{s}}=\frac{100k{\Omega}v_{s}}{110k\Omega}=0.91v_{s},
    so
    v_{s}=1.1v_{in}
    v_{L}=\frac{R_{L}v_{out}}{R_{L}+R_{out}}=\frac{100{\Omega}v_{out}}{110\Omega}=0.91v_{out}
    \frac{v_{s}}{v_{L}}=\frac{1.1v_{in}}{0.91v_{out}}=\frac{1.1}{0.91}*\frac{1}{100}=\frac{1.1}{91}=0.0121
  2. Veracohr
    Jan 3, 2011
    559
    77
    Voltage gain is expressed as the ratio of the load/output voltage to the source/input voltage: Vl/Vs.
    You have Vs/Vl.
  3. nDever
    Jan 13, 2011
    154
    I thought that too, but when a ratio is expressed as A-to-B, isn't it A : B or A/B? The exercise wanted the source-to-load voltage gain.
    EDIT: Nevermind. I understand; "source-to-load" is specifying the elements it's interested in, not mathematical notation.
