amplifier
Discussion in 'General Electronics Chat' started by pinoyballer, Dec 8, 2007.
  1. pinoyballer
    Oct 31, 2007
    11
    when i simulated an amplifier in pspice the two inpute terminal were not the same. why. i thought they should be.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    with two inputs, the amp is probably a differential one. That means that one input will follow the input, and the other will invert it.
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    Two inputs are very handy. Not only you can build a inverting or non-inverting amplifier, but also you can set the gain. Operational amplifiers have two inputs and a very large gain. The gain is normally unstable, but with a negative feedback network you can build a very stable amplifier. Of course, op-amps have many purposes. They are the most versatile amplifiers you can find.
  4. kubeek
    Sep 20, 2005
    4,691
    806
    The other input is at the same voltage only if there is feedback involved, and the amp isn´t near clipping conditions.
