amplifier
Discussion in 'Homework Help' started by icyzero, Jan 26, 2007.
  1. icyzero
    Jan 26, 2007
    its required for me to do an amplifier circuit using a common emitter BJT...
    and in the evaluation i think they will ask two question that yet i codnt get an answer for em...
    why its better to use a common emitter rather than common base?
    and if we changed the saturation current Is without changing the doping of the material... wat will be the effect?
    i really need those answers... the evaluation is on next monday...
    SOS !!!!!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We look to you to do the work. If you come here with some work to show, we can probably help. Otherwise, it is like you are asking us to do your work, and we don't get the grade/recognition.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Better for what exactly? I can think of two or three applications where a common base amplifier would be more useful.
    Change the saturation current?!? Change the doping material?!? I would love to see a demonstration of this.
  4. extremeads1
    Feb 10, 2007
    64
    As you are using the BJT as an amplier device the gain provided By the BJT must be maximum .
    When The BJT is operated in CB configuration the gain factor ;
    a= Ie/Ic & Ic=Ie apprx. hence the gain is 1
    It simply means that o/p is same as i/p.
    However in CE configuration gain =Ic/Ib where Ib is in microamps and Ic is in milliamps calculate it its found that the ratio is high which means amplification takes place max in CE configuration.
