amplifier
Discussion in 'General Electronics Chat' started by electronics1, Feb 19, 2010.
  1. electronics1
    Thread Starter Active Member
    Aug 21, 2009
    42
    My question is related to this chinning
    http://forum.allaboutcircuits.com/showthread.php?p=213852#post213852
    Thanks for the answers
    But this is not what I search
    When I connect the audio signal to the transformer that the first coil is approximate 60 ohms (thin wire and a lot of wrapping) and the second coil have 2 ohms (thick wire and littile of wrapping) and this connected to a button loop (very thick wire with length of 50 cm)
    In the button loop create a magnetic field and this magnetic field I can receive from 50 cm
    With other button loop and then I transmit the magnetic field back to audio signal
    The transformer used for passive transmits voltage to amperage.
    I need to do an active amplifier for voltage to amperage
    The audio signals will amplify and will transform to very strong amperage into the bottom loop and then will create a very strong magnetic field and the system will be smaller and lighter
    I search after information about how to build this amplifier
    And search after electronic circuit sketches that can do this.
  2. electronics1
    Aug 21, 2009
    42
    ! anybody !
  3. electronics1
    Aug 21, 2009
    42
    somebody !
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    You did not post your schematic so we don't know what you are talking about.
  5. electronics1
    Aug 21, 2009
    42
    I search information of how to build an amplifier for voltage to amperage
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    Does your transformer have a laminated iron core?
    Your primary winding has such a high resistance that most power will be wasted in the resistance. The voltage at the output winding will be the ratio of the number of winding turns minus the losses in their resistances and on the load resistance.
    The current in the low voltage winding also depends on the ratio of the number of winding turns minus the losses in their resistances and on the load resistance.
