amplifier
Discussion in 'General Electronics Chat' started by electronics1, Feb 12, 2010.
  1. electronics1
    Thread Starter Active Member
    Aug 21, 2009
    42
    I want to transmit a song through inductive button loop to amplifier
    I need to build amplifier that take the audio signals to cause an electric current flow into a button loop with diameter of 50 cm in a sufficient strength that generate a magnetic field that can receive the button loop that have some distance from the transmitter.
    I understand that the magnetic field depend on the current strength that pass into the button loop and I need to build an amplifier that take the audio signals and amplify the current
    What kind of amplifier I need ?
    I want to learn this subject and I search after sites that explain this.
    I search after electronics circuit that do this current amplify
    The button loop was build with transformer but the magnetic signals are weak and I need to amplify the active current
  2. electronics1
    Aug 21, 2009
    42
    ! - u - p - !
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Do you have the current schematics?
    With the schematics at hand we can have a look how to modify it.
    Greetings,
    Bertus
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Some concert halls used an inductive loop around the room and deaf people wore an inductive receiver that had very high gain.
