Amplifier with jfets and laterals
Discussion in 'The Projects Forum' started by Experimentonomen, Jan 27, 2012.
  1. Experimentonomen
    Feb 16, 2011
    331
    46
    Heres another project of mine from last year, that i dug out, dusted off and fixed up.
    A amplifier using jfets in the input stage and laterals in the output stage.
    This amplifier is unique from my other projects in the sense that its dc coupled, which means there are no capacitors in the signal path to cause low frequency rolloff, instead this amplifier has frequency response down to DC.
    The overall design is based off of several commercial amplifier topologies including D Self's "blameless" mixed together, and with some of my own ideas mixed in.
    The overall schematic:
    http://i.imgur.com/XSIEd.png
    And a picture of the actual unit:
    http://i.imgur.com/uEp0M.jpg
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    I think you meant to post this in the completed projects section? Cool circuit, BTW.
  3. Experimentonomen
    Feb 16, 2011
    331
    46
    Tecnically its not done, i just cannot proceed any further due to lack of tools for metalwork.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Do you select the JFETs for matching?
  5. Experimentonomen
    Feb 16, 2011
    331
    46
    No need to, the jfet is one of those dual ones, two in same package.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I can find spice models for the J2SK332, but no datasheet, and no vendors. Can you post links to these?
  7. Experimentonomen
    Feb 16, 2011
    331
    46
    These Jfets are obsolete since decades ago, i was lucky to find three on ebay.
    I think you can still get the 2SK389 from digikey, mouser or farnell, its in a different package but should still be a suitable replacement.
  8. atferrari
    Jan 6, 2004
    2,670
    785
    Hola Ron,
    In this site there are some listed:
    http://www.rfcandy.biz/shop/
    I do not know if they will be of use for you.
    Look in the left side menu
  9. Ron H
    Apr 14, 2005
    7,050
    657
    I couldn't find them at that site.
    Thanks for looking, Agustin. I'm not in the market for them. I was just curious to see a datasheet, and that's when I discovered that neither the part nor its datasheet is readily available.
  10. Experimentonomen
    Feb 16, 2011
    331
    46
  11. Ron H
    Apr 14, 2005
    7,050
    657
    I don't see any matching specs.
    Matching may not be critical. With a closed loop gain of 28.5, you'll get 28.5mV of output offset per mV of input offset (if your current mirror is perfect - it won't be). If the transistors are matched within 20mV (my arbitrary guess), that's 590mV of output offset. with a 4 ohm load, you'll have 150mA of current imbalance in your output drivers. Will that cause significant distortion? I have no idea. Does a current bias cause a problem with speakers? I don't know.
    EDIT: What's the purpose of the RC network on the input?
  12. Experimentonomen
    Feb 16, 2011
    331
    46
    To remove unwanted rf from the input, without it you can sometimes hear radio stations when using long audio cables, i've heard stories of guitar amplifiers picking up radio stations from other countries.
    This amplifier with no signal is dead silent and measured dc offset on the speaker outputs are 10-25mV.
    It has strangely also has better psrr than my bjt amps which audibly hum on idle.
  13. Experimentonomen
    Feb 16, 2011
    331
    46
  14. atferrari
    Jan 6, 2004
    2,670
    785
    Sorry Ron, there are some dual FETs. Not the ones you were interested on.
  15. Experimentonomen
    Feb 16, 2011
    331
    46
