amplifier types
Discussion in 'Wireless & RF Design' started by bhuvanesh, Mar 23, 2014.
  1. bhuvanesh
    Aug 10, 2013
    268
    i want to be clear of what actually current and voltage amplifier does.and how it varies from power amplifier.thank you in advance
  2. radiohead
    May 28, 2009
    474
    31
    Power is measured in watts, so a power amplifier would be something that would amplify an audio or RF signal.
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    Voltage amp amplifies Voltage
    Current amp amplifies Current.
    Power amp Amplifies Both VI.
  4. davebee
    Oct 22, 2008
    539
    46
    Amplifiers are usually named for their primary role.
    The primary task of a voltage amplifier is to increase the voltage of a signal, so they are referred to as voltage amplifiers, even though they often amplify the power of the signal as well.
    The primary task of a power amplifier is to provide power to drive a load, such as a speaker or an antenna, so they are referred to as power amplifiers, even though they often also amplify the signal voltage in that process.
  5. MrChips
    Oct 2, 2009
    12,643
    3,457
    Voltage amp amplifies voltage, but the output current might be limited.
    A power amp tries to keep the output voltage constant over a wide range of loads.
    Current amp amplifies current, but the output voltage might be limited.
    A current amp tries to keep the output current constant over a wide range of loads.
