amplifier question
diwa2000@gmail.com
Joined Apr 15, 2008
40
hello guys
can anybody please tell me why does an output of an LM741 amplifier does not completely reach the supply rails. For example in my case the supply voltages are +5/-5V and at 500mV the output is 3.36V. the gain is 10.
Please help
Wendy
Joined Mar 24, 2008
23,421
There isn't a secret about it, the datasheet of a 741 also includes the chips schematic. Basically it is the output short circuit protection, which makes the chippie so useful for beginners.
You have to realize how old this chip really is. The fact it is still so useful is a testament to the designers.
blocco a spirale
Joined Jun 18, 2008
1,546
I'm not convinced that the 741 is such a good device for beginners. I know it appears in many textbooks but it can be difficult to use due to requiring split rail supplies and of course its inability to get anywhere close to the supply rails. Is it unity gain stable? probably not. There are lots of modern op-amps available which exhibit near ideal behaviour and are suited to low voltage single-rail battery power applications.
Anyone inexperienced in electronics could easily waste a lot of time going round in circles trying to figure out why their circuit isn't behaving as expected when in fact the problem is due to the limitations of the 741.
SgtWookie
Joined Jul 17, 2007
22,230
If you want the output to reach the supply rails, you will have to use a much more modern op amp.
Look at AD8051, LM6132, LM6152, LMH6642, OP179, there are many others.
Audioguru
Joined Dec 20, 2007
11,248
The lousy old 741 opamp is 40 years old this year. It was designed to use positive and negative 15V supplies, its max output was +13V and -13V, its high level response was from DC to only 9kHz and its high noise level is not spec'd.
May it rest in peace.
JoeJester
Joined Apr 26, 2005
4,390
As long as the 741 is useful ... it will remain. It's deficiencies show up very easy on lower bandwidth scopes to illustrate the problems one can encounter.
Other than the training enviroment, I would agree, may it rest in peace. I think it will be around for quite some time though.
