Amplifier power output
Discussion in 'General Electronics Chat' started by justin77, Apr 10, 2010.
  1. justin77
    Apr 3, 2010
    19
    How can i measure the power output of a audio amplifier?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can always work from the power supply, and calculate the maximum current possibel times the voltage, and say that it is capable of that power out.
    Otherwise, you need a load resistor that can handle the expected power and attach it in place of the speaker. Apply a 1 KHz sine wave signal at the amplifier input and increase it until the sine waveform across the load resistor starts to clip. Back off until the sine wave is still undistorted, and measure the voltage and current being developed across the resistor.
    Note that the resistor value can be quite important. Speakers used to be characterized as 8 ohms. To avoid relatively large voltages driving current, speaker impedances are sometimes down around 2 ohms. You need to know the expected load impedance in order to select the correct load resistor.
  3. Jazz Bass Special
    Apr 9, 2010
    24
    5
    For your own information when you do measure the Vac at the output load.
    The formula is :p= VxV/R
    Where P is wattage, V is output voltage (RMS) & R is the load resistance on the output.
  4. justin77
    Apr 3, 2010
    19
    Is it okay to take the reading across the speaker using a analogue multimeter
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    An analog voltmeter is made to measure the 50Hz or 60Hz mains frequency. Its accuracy at 1kHz to 20kHz will be poor and it will probably measure too low. You need a good speaker and good hearing to hear when the amplifier begins to clip so you can reduce its input a little. I use my oscilloscope.
