Amplifier plays loud humm
Discussion in 'General Electronics Chat' started by kaae, Nov 3, 2013.
  1. kaae
    Oct 2, 2013
    13
    Hi, i Got a subwoofer amplifier that i leant out for some friends. I guess after playing loud on it for some days it just suddenly began to play a really loud huming noise 60 hz i Would guess,its so loud that you cant hear the Music Being played. And already if i turn up the attenuater to like 10 a clocl. it Will make the bass driver play really loud and almost hit it's x-max, like if the amplifier gets a really loud signal.
    Any ideas what could be Wong. I have already opened it but couldn't see any defect or suspecies components.?
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    What the heck! You must think we have supernatural powers.
    To begin, what is the make and model of the amplifier?
    Do you have a schematic or can you lead us to the link for a schematic?
    So you've already opened it and expect us to imagine what you saw. Show us some photos, clear and well focused, please.
  3. Dodgydave
    Jun 22, 2012
    5,159
    772
    Sounds like mains hum to me, open circuit ground cables, or power supply smoothing capacitors gone duff..etc..
  4. kaae
    Oct 2, 2013
    13
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    If I had to guess I'd say it's some bad filter caps in the power supply. That's usually the cause of mains hum in amplifiers. Check the power supply for bulging or leaking capacitors. But keep in mind, even if they aren't visibly bulging, they could still be dried up and damaged on the inside.
    Matt
  6. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Also check input sockets for damage, which might have resulted in an open circuit ground as mentioned in post #3.
  7. tubeguy
    Nov 3, 2012
    1,157
    197
    Thanks for the video.
    It appears to be a problem with the input section, (prior to the volume control), because it appears to stop when you turn down the volume,
    It sounds like a motorboating type of oscillation, not exactly a power supply hum.
    Do you have any test equipment ?
  8. MrChips
    Oct 2, 2009
    12,648
    3,458
    I agree with tubeguy.
    That is called motorboating, not supply hum.
    The noise is from the input stage, not the power amp output stage.
    Most likely coming from the section under that metal shield.
  9. kaae
    Oct 2, 2013
    13
    okay, so how should i approach it, you say it might be the input section, so is there any way i can measure my way towards the fault ?
    i only got an multimeter, no osciliscope.
    thanks.
  10. MrChips
    Oct 2, 2009
    12,648
    3,458
    You will have to reverse engineer the input section, i.e. try to draw the circuit schematic.
    Start with the input jack and try to visually trace where the signal goes and draw all the connections. If you can provide clear photos of the top and bottom side of the board of the input section I'm sure someone here can help you.
  11. MrChips
    Oct 2, 2009
    12,648
    3,458
    You could also start at the power supply into the input board.
    Look at the four capacitors at the left hand side of the board and replace those.
  12. MrChips
    Oct 2, 2009
    12,648
    3,458
    Another suggestion is to locate the two large capacitors on the main power supply and replace those.
  13. kaae
    Oct 2, 2013
    13
  14. kaae
    Oct 2, 2013
    13
    earlier iv'e already suspected the two largest capasitors but one one of them looked suspicies, so i replaced that one but it didn't change anything. so i guess i have to rule those ones out, i might try and replace the smal ones though as you said.
  15. MrChips
    Oct 2, 2009
    12,648
    3,458
    Thanks. I will have to give this some thoughts.
  16. MrChips
    Oct 2, 2009
    12,648
    3,458
    There are two dominant frequencies in your sound clip, one at 30Hz and another at 83Hz.
    That could suggest that this is not 60Hz AC hum pickup.
    Motorboating can be caused by feedback in the amplifier circuitry where a large current draw causes the power supply to drop and is fed back through the input stages via the power supply or via the preamp inputs.
    The fact that the hum goes away when the volume control is turned down should provide some kind of clue.
    Having no circuit diagram and no oscilloscope presents quite a challenge to fixing this one.
  17. kaae
    Oct 2, 2013
    13
    Thanks after replacing the Four smaller capasitors the motorboating disapeared !
    Havnet tried it out with input signal yet but everything seems fine for now.
  18. crutschow
    Mar 14, 2008
    13,509
    3,385
    Motorboating can be caused by bad filter capacitors. I would check the electrolytic filter capacitors connected to the power rail(s) on the signal board. One quick way to check is just to temporarily connect an equal or larger capacitor across each of the ones on the board, one at a time, and see if it changes the motorboating.
