Amplifier picking out parts.
Discussion in 'General Electronics Chat' started by Seb1929, Feb 20, 2015.
  1. Seb1929
    Feb 20, 2015
    26
    Hello! I'm a bit off a newbie and can someone help me pick out parts for this amplifier?
    I don't need the 50K potentiometer.
  2. #12
    Nov 30, 2010
    16,655
    7,292
    What? All the parts are labeled. The only thing left to the imagination is that the capacitors should be rated for at least 16 volts and what country you are in.
    Seb1929 likes this.
  3. Seb1929
    Feb 20, 2015
    26
    Should i use aluminium or ceramic capacitors?
  4. crutschow
    Mar 14, 2008
    13,460
    3,353
    Where did you get that schematic?
    It doesn't correspond to the data sheet I found.
    Seb1929 likes this.
  5. Seb1929
    Feb 20, 2015
    26
  6. #12
    Nov 30, 2010
    16,655
    7,292
    Yes. The big ones are aluminum and the small ones are ceramic.
    Another way to say this is, Try buying a 100 uf ceramic capacitor or try buying an aluminum 0.1 uf capacitor. Not likely you can do that.
    Seb1929 likes this.
  7. Seb1929
    Feb 20, 2015
    26
    Oki tnx.
  8. crutschow
    Mar 14, 2008
    13,460
    3,353
    That schematic is incorrect. Look at this data sheet (compare the output capacitor values).
    Seb1929 likes this.
  9. Seb1929
    Feb 20, 2015
    26
    Okay thank you!
  10. #12
    Nov 30, 2010
    16,655
    7,292
    Crutschow just named the difference.
    and the M only describes the plastic DIP package.
    Seb1929 likes this.
  11. bertus
    Administrator
    Apr 5, 2008
    15,792
    2,382
    The difference between the TDA2822 and TDA2822M is that the TDA2822 is 16 pins and the TDA2822M is 8 pins.
    There is even a TDA2822D wich is in a SO8 housing.
    See the both attached datasheets to compare them.
    Bertus
    #12 and Seb1929 like this.
  12. Seb1929
    Feb 20, 2015
    26
    Can i help finding a 470uF capacitors that are not either higher than 5MM or has a diameter of 5MM
  13. bertus
    Administrator
    Apr 5, 2008
    15,792
    2,382
    Where are you located?
    That way we can perhaps give you localized advice.
    Bertus
    Seb1929 likes this.
  14. Seb1929
    Feb 20, 2015
    26
    I live in Norway.
  15. bertus
    Administrator
    Apr 5, 2008
    15,792
    2,382
    Seb1929 likes this.
  16. Seb1929
    Feb 20, 2015
    26
  17. Seb1929
    Feb 20, 2015
    26
  18. bertus
    Administrator
    Apr 5, 2008
    15,792
    2,382
  19. Seb1929
    Feb 20, 2015
    26
    Yeah, Is there any other solution instead of one 470uF? Or is there another amplifier instead of 2822M where i don't need as big capasitors?
  20. #12
    Nov 30, 2010
    16,655
    7,292
    The capacitors are dictated by the speaker impedance and the low frequency range.
    You can forfeit some low frequencies by choosing less capacitance.
    You can choose higher impedance speakers, but the penalty is that less power will be delivered because of the low voltage available.
