Amplifier help
GARYN
Joined Sep 4, 2009
47
Hello, A friend has given me a sound system kit (fits into backpack) to look at, it comprises of a MP3 Player, battery powered amplifier, and two 8W (8ohm) speakers.
The system worked fine (bought new a year ago) but now the sound from the speakers when connected through the amp is poor (buzzing and humming) but when connected to the MP3 direct the sound is clear but obviously quieter.
Is the amp faulty or are the speakers damaged and it only shows when the higher power from the amp is connected.
My electronic knowlege is basic, any advice on what to check would be appreciated.....
harsha429
Joined Sep 19, 2009
nice question u r using ohm speaker right , u do one thing i.e connect another speaker to amp and check it once it again repeated it may be due to the amplifier fault so first check speakers once and then amp............................... thank you.harsha
Wendy
Joined Mar 24, 2008
23,421
Sounds like some bad connections have developed. If you're using jacks to connect this arrangement that would be the first place I'd check.
