Amplifier Gain Charactersitics
Discussion in 'Analog & Mixed-Signal Design' started by Nathan Hale, Oct 15, 2016.
  1. Nathan Hale
    Thread Starter Active Member
    Oct 28, 2011
    125
    Hello Folks. I am trying to solve an amplifier problem.
    I believe the DC gain of the circuit below is ( -10k ÷ 1k). Can you please let me know if that is correct?
    I also think the AC gain would be [ (- 10k)(1k - 1000j) / (1k) (-1000j) ].
    Did I figure out the DC and AC gains correctly?
    Thank You
    p.s. I am calculating the closed loop gain here, keeping in mind that this is an inverting amplifier.
  2. shteii01
    Feb 19, 2010
    3,505
    512
    Why did you leave capacitor out?
  3. Nathan Hale
    Oct 28, 2011
    125
    Cause the problem is asking me to find the DC and AC gains. i figured in the DC gain scenario the capacitor is nothing more than an open wire.
  4. shteii01
    Feb 19, 2010
    3,505
    512
    I believe your DC is correct. DC will not interrupt, the capacitor will fully charge and, in DC environment, will act as open circuit. Therefore the gain is determine my only R1 and R2, like you have done.
  5. Nathan Hale
    Oct 28, 2011
    125
    What about my AC gain? Did i figure out the AC Gain correctly? Can you please comment on my AC gain?
  6. ramancini8
    Member
    Jul 18, 2012
    447
    119
    yes you did the ac correct, but it might be better expressed as G = (R1/R2)(s + 1/R2C2) where s = jw.
    Nathan Hale likes this.
  7. shteii01
    Feb 19, 2010
    3,505
    512
    I think w might be giving to OP. They just did not tell us what it is. That would explain the -1000j Ohm value of the capacitor. There is no need to go to s domain because w does not change, it is constant and is known to OP.
  8. ramancini8
    Member
    Jul 18, 2012
    447
    119
    In the s domain representation it is simple to graph the result in a Bode plot form so further analysis can be done visually. A matter of preference I think.
  9. anhnha
    Apr 19, 2012
    776
    48
    No schematic?
