amplifier for Rogowski Coil
Discussion in 'The Projects Forum' started by abadi, Mar 23, 2010.
  1. abadi
    Nov 8, 2009
    hi guys
    im almost done with my project , but im facing 1 problem with my amplifier that amplify the output of the coil,
    this is the experiment i have done .
    first , i set the function generator to max amplitude which gives 23V Ac at the oscilloscope and start with 30k f and its sin-wave .
    and this is my steps;-
    1- i use the function generator to produce a frequency that pass through the coil
    2- i measure the output of the coil by using an oscilloscope to see the wave form then see the V-peack value
    3- i start it with 30K f, and its give me 22mV AC from the coil.
    4- i increase it to 60K f , and its gave me 38mV AC from the coil.
    5- increase it to 90k f , and its gave me 52mV AC from the coil.
    and its going on
    when i increase the frequency the wave will increase and also the V-peak value ...
    my question are
    1- how much gain i have to use to amplify the signal ..??
    2- my gain should be dependent base on what ?
    thanx alot
  2. abadi
    Nov 8, 2009
    neeeeed hellllp :(
  3. Bychon
    Mar 12, 2010
    Your gain should be dependent on how much voltage you want to have after the amplifier has amplified.
