Amplifier designing with 6 desired properties
Discussion in 'Homework Help' started by kmkl, Dec 29, 2010.
  1. kmkl
    Dec 29, 2010
    33
    1-) Ri:100kohm
    2-) Ro:1kohm
    3-) output power: 15w
    4-) gain: 60dB
    5-) THD < %5
    6-) Bandwidth: 100Hz-100KHz
    (allowed parts: R, L, C, Bjt, Opamp, Power transistors as many as you want)
    i know it is difficult. but it is my vital homework ever. ANY help, ANY clue will be appreciated. thank you.
  2. kmkl
    Dec 29, 2010
    33
    :confused: :confused:
    which part should i start with....?
    or, which property should i provide firstly?...
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    First you should start form pickup the right diagram.
  4. kmkl
    Dec 29, 2010
    33
    it looks too complicated for me, cant we realize that with more simple circuit ?
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
  6. kmkl
    Dec 29, 2010
    33
    thanks for your help and interest. my teacher said about the homework that,
    "it is easy, except 20w power at Ry it can be implemented with only 2-3 stage transisor.
    to suply power, you should add some power transisors parallel to Ry"
    and the matter is, i am not good at this lesson, and i cant do it on my own. :(
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
  8. kmkl
    Dec 29, 2010
    33
    yes it is but still too complicated. at least for me.
  9. kmkl
    Dec 29, 2010
    33
    the output impedance is desired <0.25ohm.. is it possible?
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    So what type of a amplifier you are familiar with?
    Yes, if you use a large amount of a negative feedback
  11. kmkl
    Dec 29, 2010
    33
    i can only understand from simple bjts. here is the project i am trying to complete.
    • ccc.pdf
      File size:
      75.8 KB
      23
  12. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hmm, so maybe this diagram
      File size:
      18.4 KB
      52
  13. kmkl
    Dec 29, 2010
    33
    well, what about the values ?
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    If you don't know how to calculate the values of the extremely simple power amplifier then you should repeat (fail) the course.
    Whe did your extremely simple preamp have capacitors with a value of 10000000000uF?
  15. kmkl
    Dec 29, 2010
    33
    i just need to do this homework.
  16. kmkl
    Dec 29, 2010
    33
    i managed to adjust gain and bandwidth on "Vp", but when i add power transisors, everything loses up. and gain falls to -50dB.. whats wrong :confused::confused:
  17. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well, Q4 is off (cut-of) all the time.
    And Q3 has small current gain so he heavily loads Q5 amplifier.
    And this is why voltage gain drop.
    kmkl likes this.
  18. kmkl
    Dec 29, 2010
    33
    i had tried to add an ab class power amplifier behind Vp, but output dc voltage were supposed to be 10v (vcc/2), but it is not too. is it because r9 is too small? how can i make that power bjts work ?
  19. Jony130
    Feb 17, 2009
    3,990
    1,115
    Maybe becaues you forgot to add capacitor between output stage and R9.
    And by the way, you need power supply voltage to be grater then
    Vcc > 2 * √(2*Pout* Rload) = 25V
  20. kmkl
    Dec 29, 2010
    33
    ok. i will add capacitor, there and then
    as i understand, all i have to do is to change V2 for arranging power to 20w,
