Amplifier Design Problem (High gain, high BW)
Discussion in 'Homework Help' started by Schniz2, Apr 15, 2010.
  1. Schniz2
    Apr 15, 2010
    I need to design a multistage amplifier using 2 BJT's (1 NPN, 1 PNP) and one P-channel JFET.
    It needs to have relatively high gain and bandwidth characteristics.
    I was thinking of using a cascode amplifier design, however am not sure how to include a 3rd transistor...?
    Or would i be better off using two Common Emitter stages and a third stage with good BW characteristics... does a Common Drain?
    The JFET would be good as the first stage because if its high imput resistance (i was thinking maybe a Common Drain... does it have good bandwitdh characteristics though?)
    Another thing i guess i might need to worry about is not losing too much current through the stages.
    Any help woudl be much appreciated!
