Amplifier design level shifting stage w/ current source equations
Discussion in 'Homework Help' started by wazzizit, May 30, 2015.
  1. wazzizit
    Jan 14, 2015
    19
    Could anyone help by giving the equations used to calculate the resistor values in the circuit attached please?
    Many Thanks :)
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    All transistor in your diagram are connected backward or simply you are using wrong transistor type.
  3. wazzizit
    Jan 14, 2015
    19
    The top and bottom power supplies are the wrong way round. Assuming they're flipped, how do I derive the res values please?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well all you need is Ohm's law and two Kirchhoff's laws.
    Ic2 = Ic1 = Ic3 = (Vd - Vbe1)/R1
    And
    Vo = Vi + Vbe3 +Ic3*R3
  5. wazzizit
    Jan 14, 2015
    19
    Any chance you could sub in some values please? I'm struggling to know what the Vbe, Ic2, Ic1 and Ic3 values are
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    You do not know what Vbe is ??
  7. wazzizit
    Jan 14, 2015
    19
    I know it's the voltage from base to emitter...
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    And typical Vbe values is ??
  9. wazzizit
    Jan 14, 2015
    19
    .7V?
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes.
  11. wazzizit
    Jan 14, 2015
    19
    Always? how about the currents?
  12. crutschow
    Mar 14, 2008
    13,479
    3,367
    You need to take a stab at it before we can help.
    The is Homework Help forum, not a Do Your Homework one. :rolleyes:
  13. wazzizit
    Jan 14, 2015
    19
    Please see my other thread where I have posted half of my efforts on this task so far.
  14. Jony130
    Feb 17, 2009
    3,990
    1,115
