I'm struggling to make progress on a problem...
I require amplification of a signal from a communications modem between the frequencies of 100kHz and 1MHz. It is to drive an inductive coupler to a power line. The aim is to drive current on a primary winding so the signal is induced on the secondary winding (which really is just the power line going through the toroidal inductive coupler).
Could I use an audio amplifier and extend the frequency range?
Are there any other options?
Thank you.
Thank you.
