The Electrician
- Joined Oct 9, 2007
- 2,970
First, note that R1 is not 1kΩ, it's 87kΩ
When the input to the circuit is open, the bias current through R1 leads to a voltage drop of -160 nA * 87 KΩ
This is then the input to the circuit (with the input open), and is in series with Vos and then multiplied by the gain of the circuit.
If you're not sure of the polarity of Vos, you might need to make two calculations using both possibilities.
