Ummm...yeah, audio amplifiers are usually linear, give or take a few percent, depending on how much power you are delivering. Wireless communication used to be linear, but it's mostly digital now. Compare AM radio to 256-QAM. I believe we have established as fact that you can not run a signal through an ADC converter, change some ones and zeros, run it through a DAC converter, and call it, "amplified". That will only give you a bunch of ones and zeroes at the same amplitude as the power supply voltage of the DAC chip, therefore, amplification is an analog process.I have to ask this -- if I was amplifying an audio signal or signal for wireless communication, would such an amplifier be linear by design.
Somehow, I tend to base my concept of amplifier using an audio signal.
Let me widen your view. A lot of analog design is about interfacing to the physical world. Anything that can be measured can be amplified. I have amplified signals from a parts per billion oxygen sensor. Compared to that, a microphone or an infrared remote control is easy! If I can get a few dozen nanoamps up to a level that drives a digital display, I can get it to control kilowatts of power. You can get a digital signal to control kilowatts, too, but the instant you step out of 3.3 volts or 5 volts, you need amplification. That amplification can be from way below 5 volts to get the signal large enough to run a digital input, or it can take the output of a digital chip and control some massive power. From my point of view, the whole digital world is almost a single power level, except for maybe a Class D power amplifier. All the other power levels are analog.
