Amplifier Combining
Discussion in 'The Projects Forum' started by 3BwEH, Dec 8, 2007.
  1. 3BwEH
    Thread Starter Active Member
    Feb 25, 2007
    33
    if i have an amplifier with 1 dB compression point to be +35dBm, what would be the overall 1 dB compression point of a combined amplifier stage?
    the amplifiers are combined using wilkinson divider
    :D
  2. 3BwEH
    Feb 25, 2007
    33
    :D:(:(:D
    anyone?
  3. kubeek
    Sep 20, 2005
    4,689
    806
    what does compression point mean?
    amplifiier stage combined of what?
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    "Compression point" is the power level at which gain response begins to drop off by a specified amount.
    If both amps have the same compression point, and are simply ganged with a Wilkinson combiner, wouldn't the total effective compression point simply be doubled? (At most?) Total 38dB minus combiner loss?
  5. 3BwEH
    Feb 25, 2007
    33
    yeah i guess ... but because the gain wasnt doubled so i thought that is the case for the 1dB compression point as well
    thanx anyways
