I want to amplify an AC signal of range (20Hz to 10MHz). I require gain of 3. Which op amp ic i should use and How to use it.
You can use it just like any other op amp. You just need to be careful of the layout so it remains stable.I want to amplify an AC signal of range (20Hz to 10MHz). I require gain of 3. Which op amp ic i should use and How to use it.
