amplified signal varies slowly (one way)
Discussion in 'Homework Help' started by sgesvn, May 5, 2010.
  1. sgesvn
    May 5, 2010
    Hello all of you, I'm a new member.
    I have this exercise, I urge you to discuss
    I need to do a one-way signal amplifier. the specifications of it as follows:
    - Voltage on the load 2kΩ not larger than 30V
    - High floating point 0 is less than 1.5 mV
    - Score amplification of a greater than 100000
    - AC component in the output amplifier is under 20mV
    - Current amplifier parasites of no greater than 1.5*0.00000001
    - Power consumption is greatest 2W
    - Bandwidth is from 500Hz to 1500Hz (Level 07)
    Power supply circuit for a + /-40V
    I look forward to the experts discussed!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can simply go onto sites and do parametric searches for op amps. Those +/- 40 volt supply rails will narrow choices very fast.
    sgesvn likes this.
  3. sgesvn
    May 5, 2010
    Actually, I follow the Russian vessel function. however, parts of Russia was no longer available. So, I have to do a new circuit is functionally equivalent.
    You can see the old principle of its circuits as follows:
    • YPT.pdf
      File size:
      106.9 KB
      23
