amplification problem
donpetru
Joined Nov 14, 2008
185
You should take into account the use of the input and output capacitors of 741, if the entry is about 0 ... 10mVac.
If it's 0 ... 10mVdc, then you must change strategy.
WBahn
Joined Mar 31, 2012
30,045
Why do you need thru hole?
You are working with signals levels that are going to be sensitive to noise. It might be better to use surface mount and the packages available can be done by hand pretty readily.
Alec_t
Joined Sep 17, 2013
14,313
If the amplifier has a gain G then 'offset x G' appears in the output. The datasheet should indicate how variable the offset is.
RamaD
Joined Dec 4, 2009
328
i found this chip MCP6022 http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010439 but it's offset is .5 mv , Is this .5 mv should appear in output or it will be from 0 to .5 mv and what does affect this increment ?
Is it constant over some time so i could subtract it of output if it is known ?
You could use a offset nulling circuit, which introduces a compensating offset at the input. The offset varies w.r.t. temperature, which is specified in the datasheet, which is usually quite small in precision opamps.
