Amplification and Offset
Discussion in 'The Projects Forum' started by BastiaanMDC, Jan 19, 2016.
  1. BastiaanMDC
    Oct 27, 2015
    23
    Hello I am quite new to the Opamp business, so bare with me.
    1 I am getting a -10 to 10V signal over a BNC connector 50 ohm.
    2 Then I would like to use a voltage follower followed by a voltage divider to reduce the signal to -1.5 to 1.5V.
    so far so good.
    3 After this I would like to offset the voltage signal with a Reference of 1.5V. to get a 0...3V output from the opamp stage.
    I have read that using a voltage divider and a inverting opamp causes a new thevenin voltage that reduces my amplification.
    Would it be advisable to use another Voltage follower to seperate this? just to seperate the gain and the offset circuit?
    for Opamps I would like to use the AD711
