Amplification and 50Hz Signal Rejection of an antenna
Discussion in 'Wireless & RF Design' started by Jayvin, Mar 8, 2015.
Thread Status:
Not open for further replies.
  1. Jayvin
    Mar 8, 2015
    47
    I have to design a system where an antenna has to capture a 10kHz signal. The signal has to be filtered so that there is minimum noise from power cables. To do this, i decided to use a passive notch filter to remove the 50Hz from the signal and then amplify it. However, the signal gets lost when i connect it to the amplifier, the amplifier is a non inveting amplifier with gain of 500.
    After the notch, the signal of about 200mV becomes about 10mV which i have to amplify to about 5V.
    Can anyone please help me out with this?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What is the size of this antenna, and why do you think it is picking up 50 Hz. Have you measured this?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
Thread Status:
