what can happen if I bridge 4 mono amplifer together, will my speaker die or ampli...
If the amp is a direct drive output then DC offset is a concern whether it's one amp driving the speaker or two amplifiers driving in it a bridge configuration. Don't see that two amps makes it any worse.Even bridging two amps is dangerous because you have the problem of equalizing the DC levels at the outputs or you must use capacitance coupling.
Come again !I know what that will do.
KAPOW !
Bridging will quadrangle power output. Meaning you can get 200W from two 50W amp.
What do you wanna know,Mate.Come again !
Ramesh
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Jake Hertz
