ive got a MB Quart QAA1000. it is a mono amp, and i would like to make it stereo. i have split amp stage, but cannot split pre-amp. anyone know where i can go to find out what i need to do? or have any answers? thanks in advance.
Not even at 200W by my standards (unless it is a 78bD SPL speaker). But that's because I have a sensitive hearing....
However, having 2,000 Watts for an automotive stereo is rather ludicrous. Even at 1,000 Watts, you couldn't get near the maximum output without permanent hearing damage.
Stereo means two completely different channels. That is why you have to have two amps, one for each channel. If you drive two 500W sub-woofers (I presume), you still have a mono amp.first f all, if you make a 1000W mono amp stereo, you would techincally cut it in half. therefore, it would be two channels at 500W. i pretty much know what to do, i was just hoping for an easier solution.... thanks for your time.
by Aaron Carman
by Duane Benson
by Jake Hertz
by Aaron Carman
