The accuracy of the instrument indicates how accurate you measure the current or whatever you measure. For example, if you measure 100 amps and the accuracy of the ammeter is +-5% then the real value of the measured current can be between 95-105 amps.wat is the accuracy of the ammeter and is to understand from it
by Jake Hertz
by Duane Benson
by Don Wilcher
