Ammeter adjustment / shunt
Discussion in 'General Electronics Chat' started by s57aw, Feb 12, 2014.
  1. s57aw
    Dec 18, 2013
    12
    I would like to mesure reverse voltage difference from linear potenciometer with 40uA Ammeter. I get 10.70v DC from pot and that would be full scale on ammeter and 9.50v need to be 0 on ammeter, so I need to measure 1.20 v difference and reflect it to 40uA scale.
    Would like to use that as indicator for antenna direction.
    I need to add shunt resistor and probably some resistors / trimmer in series to get just a right value.
    I am not a professional and I would be happy to get some help on this values
    Regards,
    Robert
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Just so I understand the question.... You want a 40uA meter movement to indicate zero when there is 9.5v and full scale when there is 10.7v. Is that correct?
    Again, just so I understand the conditions.
    What is the voltage source feeding the potentiometer?
  3. s57aw
    Dec 18, 2013
    12
    Yes, that is correct..
    Zero @ 9.5v and full scale @ 10.7v on 40uA meter
    Source feeding voltage to the pot is 12.05v
    Robert
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    I would start by building a voltage divider for one side of the meter (- side) to put 9.5 v on the negative terminal. I would then place a resistor (50K trim pot) in series with the + terminal of the meter and the wiper of the pot. The The voltage divide could be another trim pot , but would stay with a fairly low value with it, such as a 5k. With the antenna pointed to where there is 9.5V, adjust the pot used as a voltage divider for zero on the meter. Move the antenna to get the 10.7 volts and adjust the 50K series pot for full scale. Verify both ends and adjust until no further adjustment is needed.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Here is a drawing of what I suggested.
  6. s57aw
    Dec 18, 2013
    12
    Thanks a lot, it looks like a great starting point
    Robert
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    As a suggestion to help protect your meter, use a volt meter to set the wiper of the ZERO pot to match the voltage from the antenna pot. Also, set the Full Scale pot to the full end of range with the highest resistance. After that, it is just move-adjust, move-adjust, etc, etc.
  8. crutschow
    Mar 14, 2008
    13,502
    3,376
    You may want to protect it from overvoltage and excess current. Depending upon the meter resistance a diode or two across its terminals may provide such protection.
  9. s57aw
    Dec 18, 2013
    12
    Great support ... It works as suggested, R2 about 2.5k and R3 about 25k did the job.
    About the protection diodes over meter terminals... do you suggest diodes in both directions?
    Thanks again
    Robert
  10. crutschow
    Mar 14, 2008
    13,502
    3,376
    If the voltage polarity can only be one direction then you only need diode(s) in one direction but for general protection, diodes in both direction are better.
